problems with fan switch
1.6K views 5 replies 3 participants last post by  shoebox
#1 ·
so i finally went out and bought the parts to make my fan switch, and followed the diagram instructions from this site: http://www.xious.com/camaro/install-fanswitch.html
heres the problem, i have to turn the ac on to activate the switch. when i turn the ac on, one of the lights come on when the switch is in the center position, then i can flip it the other way and both fans come on. so i go out there later today and i put the key in and the battery is dead. i know the fans didnt stay on cause i waited and listened to see if they were still running when i got out earlier.
did anybody have similair problems with their install? can anybody maybe tell what i did wrong?
#2 ·
Do you have two LEDs with your setup?
I am going to take a guess that you are grounding out your +12v input for the LED(s) without going through one or both. If you can take a digital shot of your wiring I think it would be easy to tell you what you might have wrong. Right now there's not enough information.
#3 ·
turns out my battery cable was loose:D DUUHH!!
I'm goin to try hookin the switch back up in the moring and see if that did the trick. ill post a pick of my wiring tommorow
#5 ·
Thanks Rob for the diagram. Although I'm not experiencing any DTCs right now with my 01 wire up, I'm still going to put the 47 ohm resistors in-line to the fan wire taps. It's off to Radio Shack I go. :)
One thing I really like about having those LEDs for the fan switch is that they come on without the switch being used when the fans activate through the pcm. It's not a big deal but it's another cool way to keep an eye on what's happening with the cooling system.
#6 ·
I don't have a fan switch on mine (I have my PCM reprogrammed to lower the ON settings), but I do have the LEDs to watch the fans. I like being able to watch what is going on, too. :)
